Harrier???????? >
Harrier????????
Harrier????????
Old 05-01-2002 | 11:57 PM
Default Harrier????????
Ok...Still Learning I was looking for info on setting up your allierons as spoilers for harriers.
1) How much spoilers ..Up That is
2) Do you set up your radio so it increaces the amount of spoiler as a percentage w/ Elevator input.
Hope this enough info if not let me know...
Regards
Scott
Old 05-02-2002 | 04:39 AM
Scott
How much spoilers, will vary with each model. However 15-20% of spoilers (both ailerons raised) with full up elevator is good to start with...with this setup you should get a stable harrier...also make sure that you have about 45 deg of throw (or more) on the elevator & recommended 3D CG setup...
Hope this helps....keep us posted..
Mayur
Old 05-02-2002 | 05:33 AM
Ragz's Avatar
scott, YES to the seond question...
