flex mount for OS 160
Yeah, check out www.probuild-uk.co.uk to see some mounts and their prices. I think www.rcaerosport.com has a little bit about mounts, but it might be for the YS only.
hope it helps,
Robert.
hope it helps,
Robert.
My Feedback: (50)
rcchris,
May I ask why you want to soft mount your OS160? I think the only times a soft mount is necessary are:
1. The fuse is fiberglass and very rigid or light
2. The fuse is extremely lightly built and needs the protection
3. You're running a strong four stroke with very violent power pulses, and one of the two above plays a role.
The H9 Edge540 is a wooden structure is quite sturdy too. I can't see an OS160 shaking anything apart on that plane, and a soft mount may even rob you of some top end power.
Just my humbe input.
DKjens
DKjens
NY
I am going to try a Gator mount in mine. Some of my friends had succes with it using YS Four strokes and it doesn't require a nose ring. Available from Gator, Radio South, Central Hobbies, etc.
Piedmontmodels.com has a homemade one that looks compelling in the tech section on their website. On NSRCA.ORG there are some good pictures on Hanson's Roto mount in the Tech section.
Anthony
Anthony
Originally posted by rcchris
Does anyone know of a good flex mount for an OS 160? I know the Hydes are good, but a little pricey for my H9 Edge that I bought just for fun.
MI
I have an O.S. 1.60 FX mounted to an H9 Edge with a Dubro 1.80 sized antivibration beam mount. Why? 'cause I had it on hand. It works great, but it's pretty heavy. I'd use a backplate mount, if O.S. makes them....I think they do for the 1.60 FX.
Wiz
Wiz
