 TopCap engine 46 or 52 >
Old 11-01-2003 | 06:25 PM
Default TopCap engine 46 or 52
hi!
im new here and i have some questions about my nearly finished topcap.
i have a two engines :an "OS 46 LA" and an "OS FS52"
1. is any of these engines a good match with my topcap? will any of them be strong enough to get the topcap to hower properly? and which of them would be the best match?
2. if none of the engines i already have are good enough will a "OS 50SX" do the trick? is the "50SX" like lightyears better? [&:]
cheers
manta : norway
Old 11-01-2003 | 06:52 PM
My Feedback: (8)
Default RE: TopCap engine 46 or 52
I have an .O.S 70 four stroke on my TopCap
Old 11-02-2003 | 04:33 PM
m.gramling's Avatar
My Feedback: (8)
is this the ARF or kit.
I think if its a kit, and your weight will be close to 4.5lbs your 46LA and a moosecan should fly it pretty good. Your 52 won't have enough power.
But if this plane is the ARf or comes in at 5lbs. Your going to need a bigger engine.
Old 11-04-2003 | 07:58 PM
hovermaster's Avatar
I love my top cap, i have a Thundertiger 46. with a APC 11.5 X 4 prop. and a Max Header Pipe instead of the stock muffler. It flys great and has plenty of power with this combo.
Chris
Old 11-04-2003 | 08:48 PM
DMehalko's Avatar
My Feedback: (42)
Try the new magmum XLS .52
they run great, put out all the power you need and they are only $100
David
Old 11-05-2003 | 02:27 AM
thanks for all the answers!
i think ill go for OS50SX.
but if i were to choose betwen my 52FS and my 46LA which would be the most powerful one for my topcap?
its two years since i last flew rc planes and i want to get it up and running before i spend money on a new engine
manta
Old 11-05-2003 | 06:04 AM
My Feedback: (12)
Go with the 4Stroke from available engines.
ORIGINAL: manta
manta
Old 11-05-2003 | 05:25 PM
I have a phoenix models Fun Star 3-d. It weighs almost 5 lbs. on an old cheapo fish scal (dont know exactly how accurate it is). I have the O.S. 52 four stroke on it and it hovers great. I think that if you keep the plane around 5 lbs you would be fine. I would try it, and if you dont like it then get the 50SX.
