Adding oil question
OK so I got me Global Freestyle all ready to go and I got my YS53 four storke mounted and I got my 15% oil 10% nitro fuel ready to go. How much caster do I add to give me a 20% oil mix?
IN
You don't add ANY castor oil.....because it's a YS.
They recommend only synthetic oil for their engines.
Castor gums up the regulator and piston ring.
If you must add oil, add about 4-5 oz of Klotz synthetic oil.
For a gallon, I calculate 8 ounces.
I did this quickly, so I may be mistaken, but:
.15(128)+x=.2(128+x) Solving, I get 8 ounces.
In 128 ounces, 1 gallon, of fuel with 15% oil, there is .15(128) = 19.2 ounces of oil
Adding 8 to this gives 27.2 ounces, but we now have 128+8=136 ounces total fuel.
27.2/136 = .2 or 20% oil.
You'll need to do this in a larger container than a gallon fuel jug.
The formula, as I make it, would be:
Oil Added = (fuel amt) times (new% - old%) divided by (1 - new%)
My Feedback: (16)
GA
I would not use caster. I would use a good synthetic
ORIGINAL: Tbanister
You can download my fuel-mixing spreadsheet from http://www.redb.5u.com/
Its a 20kB MS Excel spreadsheet. Enjoy!
/Red B.
/Red B.
Adding oil will reduce your nitro content even further (below 10%). YSs prefer 20% or higher. Do the decent thing and buy some 20/20 fuel, and don't bother fiddling about mixing your own.
