which 3d plane to start with
CT
The extreme flight mini 3d is only $89!!!!!! Id check it out and go to the mini 3d threads to check out what others have to say about it!!!!!!!!!!
Josh
Josh
youve got several options...........you can with the spa3d which hovers EXTREMLY EASY almost no major stik movements and they also flat spin and harrier really good the bad things about them is no knife edge and upside down flat is hard as hell to pull off. other choices the magic 3d(a personal favorite of mine
) this plane is very cheap for 100$ but dont let the price fool you it is a 3d ing machine its hovers arnt quite as easy as the spads, but the magic is able to fly extremly slow and its ways about just under 4 pounds with a magnum xls.46 balenced. flat spins with the magic are the best ive ever seen they are so FAST AND FLAT!!!!!!!!, this plane too wont knife edge but it will fly upside down. now the best of the 3 is the morris knife put a strong .46 on it and have a whirl ive seen this plane fly and it will do almost anything
A funtana with a saito 72 is all you need when you break this engine in you will see their is no need to have a bigger saito onboard get this plane it is $169 and that is a good price for a 3D plane.
Any of the profile birds would be great. Morris Hobbies, Carl Goldberg, ExtremeFlight, Ohio Model Planes. NO Thunder Tiger, Or Hobby Crack!!!! Profile are fairly easy to mend also!
and I think they're great.
