CG EXTRA 300 recomended throws >
Old 06-15-2002 | 02:38 PM
Default CG EXTRA 300 recomended throws
I just acquired a Goldberg EXTRA 300. The plane was finished and the servos are installed. What I need to know is, what are the recommended settings for high and low rate control surface throws?
Old 06-15-2002 | 04:23 PM
My Feedback: (19)
The instruction book for the newest version of this kit gives the following suggested control surface travels.
Aileron: Low = 3/8", High = 5/8" (measure at Rib #10, wing tip)
Elevator: Low = 5/16", High = 7/16" (measure at the tip of the
horizontal stab)
Rudder: Low = 5/8", High = 1-3/16"
But these are the throws that I ended up using on my Extra:
Aileron = +/- 3/4" high, +/- 7/16" low (no differential)
Elevator = +/- 1 3/4" high, +/- 1.0" low (measured at widest point)
Rudder = +/- 2 1/4" high, +/- 1 3/8" low (measured at widest point)
Old 06-15-2002 | 09:17 PM
Thanks Dave I will get it set up tonight. Going to fly it tomorrow.
Old 11-04-2003 | 09:06 PM
dickj's Avatar
Default RE: CG EXTRA 300 recomended throws
Thanks for your good info. I too lost my spec sheet. I sure needed to know the info you posted.
dickj
