 DV building Tips >
DV building Tips
DV building Tips
Old 03-20-2004 | 11:10 PM
rgreen24's Avatar
Default DV building Tips
Hey guys I thought it may be a good idea to start a thread about building the DV. I got my started tonight. It seems like it going to be an easy plane to build. I noticed something when putting the aileron servos in. I noticed that the triangle shape where the aileron control horn is to go is not far enough out to allow maximum throw of the servo arm. No problem though. It seems that the would around that area is pretty secure and I should be able to move it to get max throw from the Servo. I am planning on using the new 635MG hitec on all control surfaces except the rudder where I will use a 645 MG.
Old 03-21-2004 | 04:13 PM
Default RE: DV building Tips
I wish I had mine already. I ordered the DV with the blue stripe. I was told they won't be in until the middle of April.
Old 03-21-2004 | 08:07 PM
rgreen24's Avatar
Need help with Interplane struts. My struts are not fitting together like they should is their anythng I can do to remedy it. The bottom fits fine but the top only the back fits, when I try to fit the front part of the strut everything comes apart
