Kyosho Majestic CG
ON, CANADA
Kyosho Majestic CG
Can some one tell me were the CG on my Majestic should be?
At slow speeds it becomes very unstable and if the engine decides to quite you can just keep it in a straight line and hope for the best (it drops like a brick).
RE: Kyosho Majestic CG
The C of G of the Majestic should be 125mm from the leading edge of the wing. This plane does not like to be flown too slowly and I would allways land mine before the tank is empty.
