MK 3D Dancer
TN
While reading some posts about the Seduction Freestyle, somebody mentioned a plane coming out soon that looked like the Excellence that "Quique Somenzini" flew. Does anybody know any details about this plane, such as who has it or is it even out yet? What is the size?
The kits is laser cut and is from MK in Japan. If you want the spec then go to www.artistic-aerobatics.com amd click on the 'airframes'. You can buy MK through HobbyNet in Japan and I believe Singapore Hobbies. No doubt central might be able to help you out in the states, Probuild would be the ones to ask in the UK.
http://www.hobbynet-jp.com/index-e.html
http://www.singahobby.com/
Hope this helps...
Hope this helps...
Its a great plane, much the same construction methods as the Seduction... however its much much bigger and built around the 91F/s. It flys the book, no worries and is a great alternative to the Seduction Demonstrator or the TopModel range. I've seen it fly and it really is a performer. Traditional contruction throughout.
My Feedback: (121)
MK kits are a bit pricey, but include ALL necessary hardware - including the tank and it is excellent quality. These are the best all balsa kits made - the wood parts all fit perfectly and can be assembled very quickly. I don't have a 3D dancer yet, but will soon. It is cheaper to get it from Singapore Hobbies, but both sources are very reputable (I've bought from both).
I'd like to read a flight report, too... anybody??
