Seduction FS v.s. Artist
NJ
has anyone flown both?
they are similar in size and geometry. if the artist flys anywhere close to the seduction, I might just get the artist because it is an ARF. time sure is scarce now.
My Feedback: (309)
CO
I see it now, like you said it looks very similar to the Seduction freestyle. I have a diabolic (also from TopModels) and am very impressed with it, both the kit quality and the flying characteristics. I also have a Seduction Freestyle kit, but have not started construction yet.
Jim
Jim
I dont consider myself an expert kit builder, but my Seduction Freestyle went together in about 2 weeks at only an hour or so a night....this thing is (I cant believe I am admitting this) easier to build than my Sig Somethin Extra. It's laser cut, and very very easy to put together. It's taken me as long to cover it as it took to build. I am sure that I will order another one of these in the future.
From the website.
Wingspan: 61.5 " Length: 55 " Weight: 4 - 4.8 lbs. 4 - 5 channels
R/E/A-F/M Engine: .40-.75 glow
Artist
$299.00
(ARF-almost ready to fly)
The Artist is an ideal as a next step for 3D and precision flying.
Can be used for glow engine as well as electric motor.
The empty weight of this beautiful machine is only 36 oz.
When you open the box the first impression is the quality, quality and again the quality.
The details are outstanding, all seams are sealed, and covering is tight. Every detail is meticulously made.
The Top Model is well known for they craftsmanship all around the Europe.
The Artist is another one from high-tech family European hand made models.
The key points: Easily removable canopy for changing batteries or easy access to the tank compartment,
fiberglass gel-coated/pre-painted cowl with molded air cooling vents, high quality hardware
and fully illustrated instruction manual full of CAD drawings.
Airfoil: NACA 64A014
Wing area: 803 sq.in.
Wing loading: 11.50 oz/sq.ft.
Empty weight: 36 oz.
(Always ask for color availability)!!!
Artist
$299.00
That being said, once I get my Seduction wing completed I will have to measure it to determine what they are using. Maybe it sucks too!! LOL
My Feedback: (12)
But....
You have to think the Artist was at least a little inspired by the Seduction, look at the upper fuse scheme, wing planform..I remember Knife Bro saying an ARF was coming, and maybe not from OK.
And now that I type this, I'll no doubt hear that the Artist preceded the Seduction..LOL
I am pumped that tmproff thought it built as easy (easier??) than a SE. That is good news, the SE was my first laser cut kit and I really liked parts that fit.
Maybe the Artist will fill the gap for people wanting a Seduction ARF...maybe it will fly as well.
Chuck,
The Seduction fuse can be built in about 2 hours, and I built both wings in one night at a leisurly pace. I think the designs are a notch up from those built here in the US. The way that you build the wing, it's almost impossible to warp it (unless you're trying). I thought it interesting that you build the horiz stab and the elevator at the same time and then cut them apart. It makes for a perfect fit. Same thing with the ailerons. You build the wing and then cut out the ailerons. Mine should be in the air by next week. I promise to post results and pics. Randy is supplying the graphics.....be sure to email him......
The geometry of the Artist doesn't look close to the pattern inspired tail moment of the Seduction. The Seduction is very close to th EZ Hyde-Away as a friend pointed out to me the other day. He gave me the landing gear from his, (crash victim) and it is a perfect match and is stiffer. Maybe this is an option for those who want stronger gear.
http://modelrectifier.com/jspages/ca...ex.jsp?cat=111
