 Twist Advice Needed >
Twist Advice Needed
Twist Advice Needed
Old 05-12-2004 | 08:06 PM
Default Twist Advice Needed
Hey all,
I would like some suggestions on tuning my Twist for better hovering. I have a OS 50SX in the nose and it is balanced at about 4.25 from the LE. When I try to go into a hover, I get alot of wing rocking and I cain't seem to hold it in a very vertical position. I have pleanty of power as I can always power out. \\
How do you have your Twist set up?
Jimmy
Old 05-12-2004 | 09:06 PM
JoeAirPort's Avatar
My Feedback: (41)
Default RE: Twist Advice Needed
Are you pointing the plane stright up or slightly forward? You might be in a steep harrier instead of a hover and wing rocking is a problem on these little ARF's. Point it straighter up or even slightly belly up. That might help.
Old 05-13-2004 | 12:00 AM
My Feedback: (7)
I have the same engine you have, good choice. I have my c.g. more towards 5" back from the L.E. I can hover mine for a long time or until I want to do something else. I plan on tail touching it tomorrow if the weather is nice. Good luck.
