Ca Models Fantasy
Hi Mark,
I saw that you have a CA Fantasy. I got one too and I am wondering what you think of it? IE what are its strengths and weeknesses, and what would you change?
Thanks!
Wild Beat.
Thanks!
Wild Beat.
Honestly, I wouldn't change much in the way of airframe and surface positions. I am getting ready to try a new surface on the pattern planes to aid in rolling loop maneuvers. Build everything to stock specs and I am sure you will be pleased. Make sure that you put the Wing Servos Perpendicular and not Parallel to the hinge line.
1.75 degrees Right thrust
0 up or down
Stab at 1/2 degree positive in relation to the wing.
Reinforce Firewall
Check Vertical CG Very Important!!!!!
Mark Leseberg Jr.
0 up or down
Reinforce Firewall
Mark Leseberg Jr.
