HYpe 3d
Hello Can anyone share their setup of the hype 3d ? I am also using the wesyon uk engine that came eithe plane
Cg location,engine, prop spoilerons,elevator flaperon %s
Where to measure the cg , cause i bought this plane from a friend aftr his 3rd flight
Hehe he couldnt appreciate a plane like this.
I think i need to shift the cg to get to tail slide
This is one awsome plane
My Feedback: (20)
NC
Wow
Your friend's loss is your gain on this one!
This plane is all about slow high alpha flight!
They say to set the CG at 150mm - 160mm ( 5 7/8" - 6 3/8" ) from the leading edge of the wing. I have mine set at 6 5/8" and it's a blast to fly!
I'm not using any spoilerons/flaperons as of yet, but would by all means suggest you play around with them.
The prop I like the best so far is the APC 12.25x3.75. My engine ( West 50 w/Throttle pipe ) is now well broken In and is making unreal power!
I took some Du-Bro pull-pull cable and made my own flying wire around the vertical and horizontal stabs gluing them in place and ending at a screw at the bottom of the fuse.
What servos are you using?
Get ready for a lot of smiling
HTH
HTH
I'm using some of the new hitehc 5475 digitals on 6 volts. These things are amazing. For power on mine I have a Saito 72, and I have a webra 50 that I may be trying out in it. Battery pack is a 5 cell 1450 nimah. I'm using a hitech electron 6 for a receiver. Prop is an APC 13x4w, running w/ 15% nitro. My setup has almost unlimited vertical. I'm balanced at the rear suggested point. I have flap to elevator and spoiler to elevator mixing at about 50%. I don't remember the exact number. Waterfalls are amazingly tight w/ flaps kicked in. Spoilers help stall the wing for high alpha moves, I've found that I've had a hard time to get the wing to stall sometimes, so kicking up the flaps with the elevator for harriers fixed that. I played around with a little elevator->rudder mixing, but found it didn't help much. The pitch coupling in ke wasn't enough that it was worth the mix to take it out. I did chop the tips off the wing though, and ke performance was greatly increased.
I agree with you dude
HIs loss my gain
this lane practically can almost land itself
I am also using 12.25*3.75
i had a morris the knife with mvvs 40 using a 11*4 prop it performed well
The west engine has way more power than the mvvs and les noise
Were should the cg be i like aft cg better TO me it handle ezier and hovering comes a wole ezier also
Again where is ya cg
thanks
HIs loss my gain
thanks
I thought the 13x4w prop was too much. Yeah I got 12k rpm with the West 50t1 but spool up wasn't that great. I'm usingh the 12.25x3.75 which is recommended in the instructions and used by the nice chap at Weston i spoke to on the phone the other day (Simon?). Fuel is ProSynth 10% - good stuff!
Not sure where my CG is (I know its waaaay back
) but my battery is behind the wing. I'll post some pics of my install when my camera battery is recharged.
bahamadude,
its a 600mah 2/3 AA nicad. I fly 3 maybe 4 flights on 1 charge and thats it, I'll charge it again. It is a small capacity but i've got a battery checker and its never gone less than full, however I won't chance my luck. It works well cos its so light! Its a great place to put the cells as it keeps the CG nicely far back.
Cabane,
good spot, yes it does need wrapping! I only just moved the battery a few days ago and wanted to go flying! Naughty naughty............
Cabane,
i use theat fntastic sticky back foam, great stuff for tight installtions.
im saying to everyone try the 13*4 APC out. its very good, i get about 13,500 RPM flat out on 10% fuel. my very heavy flip hovers lower than half power
Edible,
If you're talking 13x4w then tried it don't like it, if you're saying 13x4n then I may try it but I'm very happy with the 12.25x3.75 and am too tight to spend ÂŁ6 on a prop I may never use more than once! However I'll give the sticky foam a go, top idea..........
Andy
Andy
For wrapping receivers etc, I use bubble wrap, weighs nothing and is excellent, have the bubbles on the inside. Cheap too, check out the post office.
ORIGINAL: bahamadude
mvvs 61 i think would be perfect cause a mvvs 49 cant pull a 12.25X 3.75 the way a weston 51 can
