 ucando 46setup for 3d >
Old 05-29-2004 | 09:14 PM
My Feedback: (-1)
Default ucando 46setup for 3d
ucando 46 need help to setup for 3d
ucando w a satio 72 tried 14x4\cutdown 14x4\12x6
next 14x6.
not enough to pull out of hover/
? what is a good rpm w\14x6 prop on satio 72.
did not wieght it yet but cg aft had to add weight to nose i think 4-5 oz. to cg at 4.3\4..
?how far back can i go on cg with out making it toooo unstably..friend has ucando 60 setup 2"aft of recommended cg..have all dig hitec servos 5945 on ele,rud,a lighter for ailerons forgot number..
any other setup tips would be great just learning......[8D]
Old 05-29-2004 | 09:29 PM
Hypter's Avatar
Default RE: ucando 46setup for 3d
I have the CG on mine right at the very back of the recommended range and it was still very stable, can you move anything closer to the front of the plane? Try placing your battery pack under the tank. I have a Saito72 on mine also, with a APC 14x4w and Byron 15% fuel and it will pull out of a hover, but it really works to pull itself out. As far as RPM's go, try to keep them around 9800 RPM, generally you dont want to go over 10,000 RPM, although I've heard of people doing so without problems.
I suggest moving the RX and Battery as far forward as you can to get rid of the dead weight and balance it in the recommended range for now. Also, you could try fuel with a higher nitro content (if your not already). Good luck, its a fun plane [8D]
