Hanger9 Suhkoi HELP???
VA
Thanks guys,I've been told that I need to put down thrust in engine and adjust wing incidence.Must be that the stab is higher then wing.Itstill does'nt make any sense that to the right itpulls a tad toward gear and left toward canopy.Beyond me.It is th most pleasurable plane I have ever flown.But I can't seem to get hovering down.It seems the edge 540t does'nt have the bad tenddencys,and the stab is inline with wing.Ibet the new H9 Edge will be a great plane.
I'm not an aerodynamic expert but I:
1) find a CG that I like
2) adjust the engine thrust for perfect uplines
3) mix out any roll/pitch coupling
Trimming my planes in that order seems to result in a plane that flies pretty well.
VA
Hey Let me ask you guys another question,When you watch the pros hover and torque roll it seems the attitude of the plane is about50 tosixty degrees,and the plane does'nt move forward.Do they use elevator to flap mix.Itry and push a bit to keep from torquing aand it just flys off.
