Inside Loop Stall
My Feedback: (25)
I have a Goldberg Extra 300 with a OS120 engine. When doing a inside loop I used max elevator and the airplane goes straight up for a very short distance then moves to the left at a 45 degree angle basically stalling out and just making a complete loop. Several times it won't complete the loop. Throttle is set at half way and airplane is moving fairly quickly entering the loop. I would think the airplane would do a very tight loop and appreciate comments on if this is normal or not
I have flown a goldberg extra and the plane is just stalling a wingtip. this is because of all the throw you have in there. Try it with low rates and see how it goes. You dont need to much throw to get a nice round loop. The Goldberg wanted to stall out just when I would pull a little to much.
Andrew Jesky
Andrew Jesky
