Funtana 40 Throttle Servo
I have a JR ES306 Micro Servo that I would like to use as a throttle servo on my Funtana 40. The carb on the YS-63s is very smooth so I cannot see that the low Torque of the servo could be a problem.
Is there perhaps any other reason why should or should not use this servo. Here are the specifications on the servo:
ES-306
Type Standard
Size Super-Micro Servo
Torque 0.5 kg/cm
Speed 0.10 S/60ΒΊ
Length 21.0 mm
Width 11.5 mm
Height 19.5 mm
Weight 0.6 g
Bearings
Gears Nylon
ES-306
Type Standard
Torque 0.5 kg/cm
Speed 0.10 S/60ΒΊ
Length 21.0 mm
Width 11.5 mm
Height 19.5 mm
Weight 0.6 g
Bearings
Gears Nylon
My Feedback: (41)
RE: Funtana 40 Throttle Servo
ORIGINAL: WeedFix
ES-306
Type Standard
Torque 0.5 kg/cm
Speed 0.10 S/60ΒΊ
Length 21.0 mm
Width 11.5 mm
Height 19.5 mm
Weight 0.6 g
Bearings
Gears Nylon
ES-306
Type Standard
Torque 0.5 kg/cm
Speed 0.10 S/60ΒΊ
Length 21.0 mm
Width 11.5 mm
Height 19.5 mm
Weight 0.6 g
Bearings
Gears Nylon
If so that is a small amount of torque. I'd personally want more like 1 kg-cm (18.47 oz-in). You need some safety factor for binding and vibration (and being pushed on while you are working on it).
My Feedback: (15)
FL
I have used an Hitec HS-55 (18oz @ 6.0V) for the throttle on a Saito 40, the vibration killed the pot. Hitec replaced it, then I replaced it with a HS-85BB (no problem). A HS-81 (42oz @ 6.0V) would work also. I have a HS-85 (49oz @ 6.0V) laying around that I am going to use on my Funtana S 90 and it only weighs .67ounces. I don't recommend anything less than 18oz torque for throttle and 18oz is too low to me as shown. Any servo comparable to these listed would work fine.
NJ
Been using small servo's (HS55's, HS81's, Bluebirds) on most of my stuff lately. The only problem I've had is with a ST51. The carbs got a rubber boot on the throttle barrel. The Bluebirds and the HS55's don't have enough torque to position consistently.
Mike
Mike
