MK Elevator Bellcrank >
Old 08-12-2002 | 02:25 PM
Default MK Elevator Bellcrank
Anyone with any pictures or links to the installation of the MK elevator bellcrank assembly?
I am considering installing one in a 90 size Balsa fuselage, and would like to know if it will fit, and how it will install in a balsa fuse. I have seen several in FGlass fuses, but never in a balsa fuse.
Is it removable?
Can it be taken out for service if needed, without major work to the fuse area? etc?
Any pics,links, thoughts appreciated.
Old 08-12-2002 | 03:11 PM
Sorry I don't, but I'm looking for the same thing...best I've come up with so far is the central hobbies bellcrank
Old 08-12-2002 | 03:58 PM
This sounds like the same dilemma I'm in. I'm working on a Widebody and trying to figure out the split elevator linkage. I'm thinking of a pull-pull arrangement, but I need to figure out how to drive both halves from a single servo/tiller.
I've thought about the MK bellcrank myself, but I'm not sure about how to install it. Can it be installed in a fuselage without an access hatch?
Old 08-12-2002 | 05:03 PM
Shortman's Avatar
My Feedback: (21)
Same here guys, im going to buy it and install the bigger one on my H9 edge 540. I also have never done this before so should be interesting how it turns out.
Old 08-12-2002 | 05:07 PM
ScottK's Avatar
My Feedback: (9)
Who sells/where can I see the MK Bellcrank?
Old 08-12-2002 | 05:19 PM
www.centralhobbies.com
Old 08-12-2002 | 05:25 PM
I'm wondering how heavy it is though. I saw elsewhere on here that is weighed as much or more than putting two servos back there.
Kindof defeats the purpose if that is the case.
Old 08-12-2002 | 05:32 PM
No they arent that bad at all...I had one in my hand this week...I would put that back there instead of two servos any day. I wreck my bipe yesterday...when I get the next one, The bellcrank is going in there. I think they are a bit overpriced...we are working on something homemade. But since its here I am going to use it
Old 08-12-2002 | 05:33 PM
The MK bellcrank is easy to install, requires no access hatch, and is not heavy. rcavi8ter, (my son), has these installed on 3 planes now and we will use them on a couple more in the near future. By way of explaination, these are on 1.20 size planes and smaller, not his 33% planes.
Steve
Puckett Model Aviation
Old 08-12-2002 | 05:44 PM
To install you need only two holes in the tail where it goes. It is removable if necessary. It is very light, compared to two servos. Central hobbies sells them for $35.00. There are pictures in the ARF forum under the Aeroworks Edge 540T 60/90 topic. I put one in my Edge and really like it better than the two servos.
Old 08-12-2002 | 06:55 PM
reallly slick setup
fit between 29-54mm ( i think)
Mk has a small and a large.
go to www.gatorrc.com
