Digital Servo interferance
Hey Guys I went out today to fly my U-can-Do. and ran into to some major problems on take off. As soon as I took off I realized that my elevator was not working as they should. At first I thought I did not have enugh throw, so I switched to mid-rate. I then tried to turn the plane in and come in for a landing when again it seemed like I had no control of the plane. the Plane came down but fortunately not that much damadge, basically i broke the gera off and tore some monokote off the wing. I did a range check before I took the plane off. And Once back on the ground I did not another range check and everything seem to work out fine. I am using Hitec digitals all around except for throttle. there are two digtials servo for the elavator and for the ailerons. batteries were also fully charged. Anybody have any ideas?
