 servos for SYNERGY 90 3D >
Old 11-15-2004 | 11:54 AM
Default servos for SYNERGY 90 3D
Hi Guys
What do you all think about using futaba S3010 servos on a Synergy 90 3D?
Thank you
Old 11-15-2004 | 12:26 PM
C140 Brothers's Avatar
Default RE: servos for SYNERGY 90 3D
they should do fine but don't push it.
Old 11-15-2004 | 02:14 PM
I think to use 6V battery 2100mA so this servos should work at 6,5Kg
WHY I can't push it??
thank you
Alex
Old 11-15-2004 | 02:40 PM
Because it should really have an 8 kilo torque on the servo and a 6.5 moght strip on a wall but then again i have never flown a synergy full 3D
Adam
Old 11-16-2004 | 01:30 AM
Baper's Avatar
I am flying a SYNERGY 90 3D for 2 years now, and over 250 flights on it.
I have set up conditions on my Radio for both F3A kai 3D performance.
If you do not push it on 3D manouvers, and fly F3A style,then they should be fine.
If you push it, then it is better to go to stronger servos.
I started by using Futaba 9252 on Ailerons and Elevator, now I have setled on Hitec 5945's since in 3D the plane showed that it needed more torque servos.
I never use 6V on my planes only 4,8V, since I want to have the B failsafe from my Radio as an extra security measure.
Excellent flight performance, Good quality, attention to detail, you made the right moove buying it, just brace the tail !!!
Baper[8D]
Old 11-16-2004 | 10:20 AM
What's B Failsafe?
and is it possible fly in PCM in order to have FailSafe, isn'it?
Thank you
Alex
Old 11-16-2004 | 10:21 AM
I forgot to say in the secon question ....using 6V battery
Old 11-16-2004 | 12:19 PM
Baper's Avatar
ORIGINAL: leader22
What's B Failsafe?
Thank you
Alex
B Failsafe stands for Battery Failsafe.
It is available with PCM modulation,on the Futaba 9ZAP WC2 radio I have, when using 4,8V only , not 6V.
It is a safety feature that acts like I will describe below.
When you fly your plane, and you have enabled B Failsafe, then when voltage of the Receiver battery falls below 3,8 V and remains there for a few seconds, the Receiver recognizes that you are in a dangerous position and immediately brings your throttle servo to a preset position that you have set.
I set it at idle, so If I suddenly while I fly, I hear my engine to go to idle, then I know I have to land ASAP, because my RX battery is dying.
It is possible to regain full control on the throttle channel, by just pulling my throttle stick to idle and re advance it. This will give 30 seconds to land safely, before this feature reactivates.
This feature is not available if you use 6V battery, so I prefer to install stronger servos on my models , than using and stressing weaker on 6V.
I hope that I did not confused you more
Baper[8D]
Old 11-16-2004 | 12:25 PM
Baper's Avatar
ORIGINAL: leader22
No it will not work on 6V, cause by the time a 6V battery has droped to 3,8V, it is draining very rapidly, so there is no time to land safely.
Baper[8D]
Old 11-16-2004 | 02:03 PM
Thanks a lot Baper your explenation has been perfect .
Thank you again
Alex
