 46 3d plane with mvvs 49 will be good ? >
Old 11-19-2004 | 05:32 AM
Default 46 3d plane with mvvs 49 will be good ?
if i have a 46 size 3d plane will it do good 3d with mvvs 49 ?
thankls.
Old 11-20-2004 | 11:35 AM
Default RE: 46 3d plane with mvvs 49 will be good ?
please, i really need an answear..
Old 11-20-2004 | 12:14 PM
Boogie's Avatar
It might be really good. What are You using for muffler- standard one or tuned??
Old 11-21-2004 | 12:32 AM
i think that the tuned
Old 11-21-2004 | 09:35 AM
Depends on the plane, if it's under 5 lbs AUW you're OK.
Mike
Old 11-21-2004 | 06:42 PM
If you specified which plane it was, you would probably get more responses.
Old 11-24-2004 | 02:28 AM
i am talking about giles 202 3d : http://www.chiefaircraft.com/cgi-bin...DGiles202.html
by the way, what prop should i use with this engine and this plane ?
Old 11-24-2004 | 02:49 AM
Razor-RCU's Avatar
My Feedback: (50)
Wow! that looks like a great deal- $99 bucks huh?
Based on the span and weight the MVVS-49 should give you awesome performance- if 3D is what you are going for, then I would recommend the 12x4 APC prop. Seems like a great combo there----
Keep us posted!
james
