Which Edge 540? >
Which Edge 540?
Which Edge 540?
Old 08-23-2002 | 01:03 AM
Default Which Edge 540?
I've flown sport planes and warbirds for years and have decided I want to try a pattern plane. Is an Edge 540 a good choice to start out with? Could someone recomend a 540 kit (or ARF) that would match well with my webra speed .61 or
saito 1.20? Thanks. Randy
Old 08-23-2002 | 01:08 AM
Shortman's Avatar
My Feedback: (21)
The AeroWorks Edge 540 60/90 would be a perfect match for your Saito 1.20 and one great flying plane with supurb quality.
Old 08-23-2002 | 01:28 AM
Yepp...I hear that AW 60/90 is a lot of fun.
Old 08-23-2002 | 02:37 AM
Does that AeroWorks 60/90 Edge come in a kit? I only see it in ARF form. Seems like it would be a good size! I'm going to build the 25% AW Edge, but the 60/90 size has its appeal if I can get it in a kit. So, does it come in a kit or only ARF?
Thanks!
Reid
Old 08-23-2002 | 02:47 AM
Default Edge
Thanks for the info guys
RPLUMBO-
From looking at their website looks like the 60/90 is only an ARF, I would prefer a kit myself
http://www.aero-works.net/planes/edg...arf/index.html
Old 08-23-2002 | 03:01 AM
Go with the 25% AW Edge. Mine weighs 9 1/2 lbs with a Saito 150. A 120 would be enough at that weight.
Old 08-23-2002 | 03:04 AM
Hey lenough-
How did your Edge wind up so light? 9.5lbs seems nice and light, I've been hearing other weights of around 11 pounds. Did you do anything special? Glues? Pushrods? Servos? Engine?
Thanks!
Reid
Old 08-24-2002 | 01:16 AM
Hi rkrig,
flying the aw60/90 540,have os91fx up front,15x6 zinger prop,sig 15% fuel,had to do a lot of mods. to get it below 8#,needs os 108 to fly out of a hover,knife edge like a brick,super stable plane will do any trick in the book except a long knife edge,comes as arf only,would not buy this plane again.
Old 08-24-2002 | 01:28 AM
Have any of you guys tried any of the ARF pattern ships made by GiantScalePlanes?
http://www.giantscaleplanes.com/arfsmall.htm
Thanks, Randy
Old 08-24-2002 | 03:02 AM
Reid,
Did nothing special. It is just a lightly built plane. If you put it next to the Lanier Edge, It looks smaller. The wing chord is shorter than the Lanier and the fuselage is slimmer.
I have the Saito 150, 2 elevator servos in the tail, pull-pull rudder.
I added flying wires to the tail. That's about it. Built 3 years ago.
Here is a picture of it. I got the decals from AW also.
Old 08-25-2002 | 02:08 AM
Yellow Aircraft has a line of edges now. 30 size, 50 size, and (I think) a 120 size. They are ARF's.
Old 08-26-2002 | 01:27 AM
Default Stab Question
Lenough-
What does your elevator look like? Do the sides of the stab move as well (sort of forming an "L" shape on either elevator) or is your elevator just a straight line across the stab? I've heard this referred to as a 3D elevator/stab. Let me know if you can't understand my vague descriptions!
Reid
Old 08-26-2002 | 02:57 AM
Reid,
Your description is fine. Straight across.
Old 08-26-2002 | 02:52 PM
Default Another question!
Are the wings sheeted foam?
Thanks!
Reid
Old 08-26-2002 | 03:06 PM
Cheech's Avatar
My Feedback: (19)
My friend bought the AW 60/90 Edge and powered it with a YS .91. I flew this plane alot and although it was good, it was NOT great. It was HEAVY at over nine pounds - replace the gear and save more than a 1/4 lb I bet.
The plane was just NOT capable for the type of flight we like. He has sold it and won't buy another one. Cannot recommend
Old 08-26-2002 | 03:23 PM
Blackie's Avatar
I concur on the Aeroworks 60/90, If I had to do it over I would of purchased from creekhobbies or the sort.
Randy
Old 08-26-2002 | 09:59 PM
Banned
Default just my .02 cents
I know everyone has different opinions on which edge to fly but i have a H9 Edge with a OS160FX up front and WOW! Will do anything you want.
Dan
Old 08-27-2002 | 12:01 AM
Shortman's Avatar
My Feedback: (21)
yep
Old 08-27-2002 | 01:16 PM
Default Re: Another question!
Thanks!
Reid
The wings are foam sheeted.
