 NIMH Receiver Pack >
NIMH Receiver Pack
NIMH Receiver Pack
Old 01-01-2005 | 11:59 AM
Default NIMH Receiver Pack
first off happy new year to all.
right here goes i have just bought a weston uk groove freestyle and i want to use a 6V 2200mah NIMH Receiver Pack..will it work ok or should i settle for the 6V 1400mah NICAD Receiver Pack.
servo's will be futaba 3010's all round
engine OS50SX with throttle pipe
APC 12x6 prop
thanks miskin
Old 01-01-2005 | 12:19 PM
My Feedback: (18)
Default RE: NIMH Receiver Pack
The NiMH pack should be fine. Why do you think the NiCd would be better?
Old 01-01-2005 | 12:33 PM
i thought that nicad's had a higher discharge rating compared to the nimh batt's.
thought i would just check before i put the pack in,i didn't want to loose the plane because the battery wasn't suitable..
thanks
miskin
Old 01-01-2005 | 01:15 PM
Luke 3D returns's Avatar
That Nimh will be fine. I run my capiche 50 on an 1800 5 cell Nimh with 3010s on the ails and Hs-945 corelesses on the tail. I will be pulling more current than you with those corelesses so you should be fine.
Old 01-01-2005 | 01:29 PM
cheer's luke
that's made me feel a lot happier,i may end up with futaba 9001's on the tail they are coreless.
Old 01-02-2005 | 08:30 AM
Why do you use such large capacity batteries? When I charge my planes before going flying my charger tells me how many amp-hours it adds - it is between 200 and 300 mah after a tytpical day of flying. I fly with 650 mah packs. You don't need high amp capable packs for powering receiver/servos for small planes. My planes draw less than 1/2 amp from what I see.
Old 01-02-2005 | 09:13 AM
Ditto. AAA's on everything. A's and AA's are just a lot of extra weight.
Mike
