YS 110 oil? Synthetic?
My Feedback: (57)
WI
I just ordered my new YS 110 today. I know everyone uses 20% nitro, but is the proper oil all synthetic? At lest for break-in? Thanks for any reply.
My Feedback: (57)
WI
RE: YS 110 oil? Synthetic?
I made six calls to hobby stores around the U.S. Out of the six calls, I found two shops that had them in stock. So, I bought one. If you really want one, keep looking, they're around.
If you want a little extra kick, Cool Power 30% heli fuel works great. Lots of people I know use it, I use it and ysperformance recommends it due to the oil content. It is all synthetic.
Mike
Mike
CO
Wild Cat killed one of my engines- went from cool power 30% heli to Wildcat 20/20 and smoked my piston and sleeve in two tankfuls. I learned my lesson. Granted it was a piped Evo cranking 17,000 RPM...
Your mileage may vary.
I have a break- in question for a Saito- please don't flame me, this just seems like the right place to ask. I have a 1.80 on the way, and it's my first four stroke. I dont know how to break one in- except to run it super rich at a medium throttle. Any input would be greatly appreciated!
I also have about 2/3 gallon of 15% omega- I think it is synthetic- but with a lower oil content then the 30% heli. Would this be an appropriate fuel to break in my engine with? Is 2/3 gal enough? I was going to bolt it to a test stand for the break in- then go to the 30% when its mounted on the airframe. Once again- thank you for your input!
Cody
Cody
First, Ys does recommend that there be synthetic oil in the fuel, and full synthetic is best. Just be sure not to run actual 4-stroke fuel in a YS-that's a no no
As for your break-in question. Slobbering rich is the key for these ringed engines. Also remember that the higher the throttle setting the more fuel that is going through the engine, so I would recommend a slobbering rich FULL throttle break-in if possible, but at least half will work, too. Just be sure to monitor the temps and don't overheat the engine.
MI
Wildcat Heli fuel only has 16% oil last time I checked, even their 30% nitro version. Cool power heli fuel has 24% oil. Now I am not surprised that a engine is fried due to the low oil content.
Wildcat Heli fuel is touted as a smoke-free fuel so you don't hover helis in a cloud of smoke. Now I understand how they accomplish it: less oil residue. While it may be okay for a OS 32 2-stroke, I wouldn't use it in a YS, whose manufacture recommend at least 20% oil.
My Feedback: (26)
WI
If you did not know it already YS has a support forum right here at rcu
http://www.rcuniverse.com/forum/forumid_197/tt.htm
My Feedback: (10)
Guess i toss my 1/2 gallon of wildcat out! I thought it was more than 20%oil...i sure had a cool smoke system(It smokes quite a bit, lol, tuned right though..)Well i go check out some cool power, i only have a 1/2 gallon of the Cat in my YS so i dont think it will be any harm done....
Disregard the wild Cat fuel, unknown to me until now, it has 18% oil, not enough.
Nealio
Nealio
