 Inverted Rudder Control >
Old 02-13-2005 | 11:13 PM
My Feedback: (12)
Default Inverted Rudder Control
how do you guys fly inverted harrier's and get the rudder control correct? i can harrier all day up right, but not for long upside down........ i think rolling harriers are easier than inverted ones... any help ,hints, suggestions?
Old 02-14-2005 | 01:20 AM
Warren's Avatar
My Feedback: (72)
Default RE: Inverted Rudder Control
When inverted:
Coming toward yourself push the nose the direction you want it to go.
Going away from yourself push the tail the direction you want it to go.
Eventually; you'll not have to think about it anymore.
Old 02-14-2005 | 01:30 AM
codiddley's Avatar
Warren- is that a Kaos in your avitar?
I am learning inverted harriers too- my left thumb is sadly deficient! Not to mention the guidance system[&:] Simulators help me alot for stuff like this.
Old 02-14-2005 | 10:52 AM
lomcevek1's Avatar
You're not alone !!! The inverted harrier is killing me, so far about 3 airplanes. After I try a few times I wonder if I am even coordinated enough to walk.
Old 02-14-2005 | 11:47 AM
My Feedback: (12)
Foamie Practice.
enogh said!
This is where I am at. Eventually you wont think about it.
Old 02-14-2005 | 11:54 AM
Luke 3D returns's Avatar
Its just practise. The simulator is really useful for this.
Old 02-14-2005 | 12:16 PM
Sprink's Avatar
I have been doing inverted straight & level, pull up into vertical and an inverted stall turn (ie belly towards you) then back accross inverted again. It has improved my rudder controll inverted by huge amounts, but still not confident enough to try inverted harrier yet other than on the sim.
Old 02-14-2005 | 12:23 PM
Warren's Avatar
My Feedback: (72)
ORIGINAL: codiddley
Yup; I'm a sucker for a Kaos... Fun airplane.
Old 02-14-2005 | 12:27 PM
Ian.W's Avatar
ive found that one day it'll just click, then you wont think about it, untill then, practise!
Old 02-14-2005 | 01:56 PM
I thought the rudder stick was just a "thumb rest" when flying and only for use on the ground?
I could be wrong...
Just kidding.
This weekend I was having a blast with my Venus doing knifedge passes and figure 8s around the field.
