Video: Edge 540 .46 3D vs Funtana .46 3D
#101
RE: Video: Edge 540 .46 3D vs Funtana .46 3D
ORIGINAL: iflynething
I am using a 600maH 4 cell but I'm going to get a 1500 or something. Li-Po maybe
For small planes (like PLH Edge 46) I don't see a reason to install LiPo. Standard 6V NiMh 1200mAh will work just fine.
RysiuM
#102
NC
yeah, I will more than likely just go with a 5 cell 2000 or something. How long could someone expect from a battery with this size and my servos with normal flying an 3D?
I was thinking the same thing about the Li-Po. I'll just use it with the electric plane and go regular 5 cell for the Funtana.
~Michael~
~Michael~
#103
i use a 6 volts 1200 mah nimh on my edge and it gives me about 7 flights of 10 minutes.
Daniel
www.aerofunrc.com
Daniel
www.aerofunrc.com
#105
I decided to use this capacity not because of the flying time (my brain burns out faster than the battery) but because of the power performance. My Edge has 5 digital high torque servos plus one Mighty Mini. Even when I load all servos at the same time the voltage never drops below 6V.
But this this is overkill for 46 size and 1200 or 1500 would be the reasonable max.
RysiuM
#107
hi guys!!!
well, i just got my powerline 46-edge and i was wondering how good the covering is...
is it durable??? does it peel off from time to time???
how does it stand it after years of flying and sun shine?? does it crack after years of use???
well, if the covering is not that good, i want to recover it entirely with monokote before putting it toguether because the final product would be much nicer and easyer to do..
well, i had always used monokote and i think its the best covering available, but my funtana is covered in ultracote and its a headech, i have to iron it down or glue it down from time to time and fuel gets soak under the seems.... i never had this kind of problem with monokote, that why i love monokote and hate ultracote....well, in the other hand, i think monokote and ultracote stand the abuse of fuel and sun shine equally good after years of abuse...
well, any input in the powerline 46-edge covering will be apreciated...
thank you all...
thank you all...
#108
hey! well actually the covering is not bad! ours lasted for over a year with no noticeable problems! i think you can leave it like that and fly it!.. just remember add tail braces to the tail!!
#109
My Feedback: (37)
NC
I'm retiring my worn out Funtana and moving all the gear into the PL Edge. I should have it in the air this weekend. What's the best CG range for 3D? All up weight, anybody? [8D]
#110
My Feedback: (41)
CG is 95 mm (3.75 inches). It's about 3/16 forward of the center of the wing tube.
My weight with YS 63 and 1200 NiMh was just above 6 pounds (+ 1-2 ounces).
ORIGINAL: AHPowelson
#111
ORIGINAL: aerofundan
#113
TX
Daniel,
I just want to know what yall did to hack off that bird in the vidio. I figure maby you proped his sister.
Seriously, does the bird ever get you're plane.
In another tread you said I should come fly with you someday.
If I ever make it to Panama, I'll be sure to look yall up.
Dave
Dave
#114
ORIGINAL: Misspeld
Daniel,
Dave
Daniel,
Dave
Hey Dave!!! lol something like that
Of course if you ever make it here, you can come fly with us and have a fun time =) [8D]
#115
I'd love to see this video http://ampa.pma-net.com/aerofun/ video s/ edge vsfuntana.WMV but link seems to be dead.
Panama Guys, do something
#117
since no one replied, I have found a carbon tube from troy built models. It was a little loose but I did as they sugested and used primer to build up the diameter to a nice fit. I hope this thread is not dead, It takes sometimes six months before I finish a plane to flying status. Iam very close on this one now and will be posting some picks. I originaly wanted to put a ys .63 on this ship since I thought it would be enough power. I bought the engine and put it on a venus .40. WOW, what a combo, I highly recomend it. I lost the plane due to transmitter battery failure. Long story short I put the engine on to check for balance, with standard servos in the tail the plane is very tail heavy. It need a motor in the 20 to 24 ounce range, Including muffler. I have a .91fs that I had on a fliton 540 with a 15x4w prop that will put me in the balance area. The only problem I have with useing these big thumpers is that even at idle speed of less than 1800 the plane wants to walk away from you. I would like to know if anyone has used this engine on this plane?
