Hinge Gaps
My Feedback: (9)
KS
Should you seal both sides of the ailerons and elevators or can you just seal one side like the bottom? Also, how about the rudder....any need to seal these?
Thanks in advance.
Thanks in advance.
Sealing is to cover with clear adesive tape or covering material
the gaps between the plane and the control serfaces IE: rudder, elevator, ailerons...
why do i need to seal at all? my hinges are glued. when I was cowering my plane, I cowered ailerons and wings separatelly from all sides and then glued hinges.
