 60 U Can Do Questions/need advice!!! >
Old 06-01-2005 | 02:29 PM
Default 60 U Can Do Questions/need advice!!!
Well I have finally figured out why the 1.00 Evo Never worked on my 60 UCD. The gas tank couldn’t be lowered enough so the fuel free flowed into the carb, which caused it to load up. The manager/owner at the store is going to be nice enough to exchange this engine for store credit so I can get another engine! When mounted on a Test Stand this sucker put out Tons of power and ran like clock work! Infact it almost blew itself off of the test stand! Anyways:
I want an engine that is going to be reliable!!! Seems to me most people are flying the YS 91 on this plane. Are there any mods I'll need to do in order to accommodate this engine? Do I mount it inverted or sideways? Is there any advice that you can give me? I look forward to being able to fly my second plane finally!!!
Old 06-01-2005 | 02:49 PM
YNOT's Avatar
Default RE: 60 U Can Do Questions/need advice!!!
Put a header tank on. A small 1 ounce tank in front of the main tank. You have the room to do it in that plane. The muffler will pressurize the smaller tank and you won't have a problem. No need to change motors.
Old 06-01-2005 | 04:28 PM
I didn't think of that! I guess I should go ahead and try it out and if it works I can save myself some mula! Thanks!
Old 06-01-2005 | 06:01 PM
drumbum's Avatar
just put 2 clunks in the tank you have. called UNIFLO .. 1 on vent, 1 on pickup make them o to bottom of tank
Old 06-01-2005 | 07:57 PM
My Feedback: (17)
drumbum. Please explain a little more detail. I don't get it.!?!?!?
Barry
Old 06-01-2005 | 10:37 PM
drumbum's Avatar
this may help
http://www.rcaerobats.net/uniflow_tank_setup.htm
Old 06-02-2005 | 01:57 AM
My Feedback: (17)
Drumbum, Thanks for the info. I'm gonna try that in my UCD. It looks easy, cheap and effective. What more can you ask for.
Barry
