Best prop for 3d on a supertiger 90,
CO
RE: Best prop for 3d on a supertiger 90,
check this one out...http://www.rcuniverse.com/forum/m_3101439/tm.htm
NF, CANADA
thanks for the info xoon.Hope my engine will lift the beast,almost complete ,try her in a couple of days hopefully.
The ST G90 is not a power plant, how heavy is your plane? If its in the region of 8 lbs you really need an engine that can turn a 15x4W at 10K rpm if you can. So if its the G90 you are working with try the APC14x4W, you may get it to turn at about 10,750 RPM.
NF, CANADA
I have the same concerns about the prop.The plane will be in the 7.5 lb neighbourhood.I have all the control surfaces modified so hopefully the power is there.
