Central hobbies control rods
My Feedback: (21)
IL
I am just getting ready to build up my rods. I am going to use the JB weld as recommended by central hobbies. I am just wondering if you guys have any suggestions about making the best bond bettween rod and the rod end??? Also someone told me that I need to take percations when I cut the rod (I think so it does not fray) ANy help would be great.
Bill
Bill
Bill, Clean the inside of the pushrod with a pipe cleaner and alcohol before gluing. When I cut the CF rods, I wrap the area to be cut with masking tape and use a dremel cut off wheel. I have had good results with this method.........Jerry
MT
The dust (which is not dust its actually small carbon fibers) do not breeath it in your body cannot expell it like fiberglass. I wear a mask and gloves..
Scott
Scott
