powerline edge 46 3d/mounting moter
any one putting one together . putting a saito 82a their is not enough room to mount moter on moter box if you center moter on cross lines . are you guys mounting sideways or inverted .thanx
RE: powerline edge 46 3d/mounting moter
I think i am going to mount it inverted, with the moter inverted the thrust line will be the same as the horizontal line on the moterbox then I have the room to center the moter on the vertical line. it just seems that this was the way it shuld be ,anyone try it this way?
My Feedback: (41)
Saito 91 is fine for this plane. I have one and a YS 63 is a little low on power. The Saito 91 would be great. It will end up at around 6 pounds plus an ounce or so.
ORIGINAL: cyoung450
I have a Saito .91 that I would like to try in this plane. Will it work? Has anyone done this?
