Funtana.90 w/uniflow tank
My Feedback: (12)
MD
I'm at the point of installing a new Saito 100 ( as recommended by HH) in the Funtana, however the amount of posts about the CG and tail heavy nature with this engine is making me skectical. SO, when in doubt.... ask RCU!. Q: What if I pull-pull the rudder and use the tank set-up the heli guys use..UNI-FLOW style with pick-up and muffler pressure lines submerged then put the tank mid-ship?. May even want to mount the 100 inverted, battery on the engine box, Rx behind firewall, and throttle servo* on firewall. ? mostly I will fly mild 3D on fairly low pitch prop.
* undecided what JR servo at this time.
RE: Funtana.90 w/uniflow tank
sounds like a good idea to me...
as for the servos..go with the best you can afford. If you can afford to dish out 120 bucks a servo, go with 8411s or 8611s. At 100 bucks a pop i would go with 8417's nice and fast and OK on torque...
just my opinion im sure others with have dif. views
