saito 100 dies when trying to hover
MO
I have no experience with 4-strokes but I did set it up and tune it per the instructions. It idles pretty good, goes from idle to full just fine on the bench. When I take off and fly around it makes a slight knocking noise at 1/2-full throttle. When I went I went into sustained vertical the engine would die. What's the deal? Is the high end to lean?
One side note: the Showtime has great glide characteristics! I did 3 deadstick landings today with no problems on it's maiden flights!
TX
Check your muffler to see if it is loose. I had a similar noise on a .72 Saito and you must physically check/attempt to move the muffler to ascertain if it has come loose. I don't know if that would have any effect on the engine dying however...
Good Luck.
Good Luck.
