Downthrust on H9 CAP 232 80"?
Hi,
I'm just setting up the engine mounting for a DA-50 on an H9 CAP. Can anyone recall that has flown this plane, particularly 3D, if and what the down thrust ange was?
Lang
Lang
My Feedback: (10)
I set mine up just stock(just built it a month or two back). And eventually added 2 (1/16) washers right thrust. The rest should be built into the box.....Flies great. I would recommend a shorter standoff than the current standoffs supplied with the DA seeing as they make the cowl come out to far..... The best i can get is 1/8" clearence from the cowl with my spinner, and that is with the cowl all the way out....Good Luck, any more questions or if you need some pics just PM me at any time. The plane flies great, you will love the waterfalls and harriers!!!
Nealio
Nealio
Hi Nealio,
Thanks for your feedback. Like you did for your installation I think that I'll run with stock settings and then trim accordingly. I used the stock stand offs as supplied by DA and my DA-50 fitted nicely on the firewall. I haven't accurately set the CG yet but so far it seems to balance aout right.
I may PM you in relation to some pics, etc.
Cheers
Lang
Cheers
Lang
