Servos for H9 Ultra Stick
I just bought a H9 Ultra Stick. Iam powering this baby with a 3W-24 which will swing a 20- inch prop. I will be running the plane with flaps, but i am not sure what servos to put in it. I thinking about going with Hi-Tec. Should i use digital servos or not? What torque should i use? What speed? Should i double up on servos for elevator and rudder. One last thing i plan for this to be my 3d-Trainer, if that helps. If anyone has some advice i could use. It would be greatly appreciated. Any one that has aol instant messenger, can messege me at guru8082.
TN
A guy at our field used one to learn how to t-roll on. He had a Saito 1.80 though. One thing he did that I really liked was modify the elevator to have counter-balances. The extra surface gave him better control. Well it worked, he is now doing 3-d with the H9 1/3 Cap. On my 1/4 Katana I have the Hitec hs5625 digitals on the ailerons and the hs5645 on the elevator and rudder. They work great. Way more than enough to fly a plane of that size.
Jason
Jason
