3250 or 45cc?
CO
Supertigre 3250 or 45cc gas engine which one would be better suited for 3d in the hangar 9 extra 260? 45cc weighs 65oz with 4.1 hp.
The super tigre weighs 42oz with 3.2 hp which one is better please help!
CO
That is a very good deal but beleive it or not the st swings the same prop at the same rpms. Btw im stummped, I cant find a muffler for the st that mount vertically so you can mount the engine upside down?
CO
The only reason I wanted to run it upside down is so the head wouldnt stick out the side. Im not even sure it will. Will it? Do I need the regulator if its running side ways. Just curious will this make my 27% do 3d hard?
MA
mikmaxx,
Both Slimline and Bisson make pitts style mufflers for a side and inverted tigre mount. I currently am flying an Ultimate with the 3250 inverted and using the Slimline which is a wraparound style. I do not have a Cline regulator installed but have not experienced the need for one. I am using muffler pressure and RedMax 5%Tigre blend fuel.
This motor was well broken in before I installed it inverted into this plane which does make a difference with the tigre's. All up weight is just over twelve pounds and hovers are great (NX 18-10prop). No monster pull out, but enough..
MA
where can i get those mufflers?
And here: http://www.slimlineproducts.com/
And maybe here: http://www.towerhobbies.com/
And maybe here also: http://www.sheldonshobbies.com/listing/sli03.html
CO
Never mind the st 3250 I just won a 45cc gasser weighing in at 3.6 pounds! I got the crrc engine. Well see how this thing does! Any one with experience with this engine?
