 Carbon Fiber Props: functional, or beautiful? >
Old 01-14-2006 | 02:12 PM
My Feedback: (52)
Default Carbon Fiber Props: functional, or beautiful?
Hey, i'm obsessed with Carbon Fiber and was wondering if the experianced users found it worth the money... right now i run a 16*6 apc on my ys 110.... one of my problems is that i can't find a cf 16*6 online, only a 16*8... so if i got a 16*8 would i see more performance to run an 8? so these are my questions... if you know where to get a 16*6, please be so kind to post a link
thanks!
Old 01-14-2006 | 03:56 PM
cstevec's Avatar
Default RE: Carbon Fiber Props: functional, or beautiful?
Carbon fiber = zero flex = more performance. However, that performance is usually realized with bigger engines, not engines that use a 16" prop. In your case, the APC 16X6 is a good prop that doesn't flex much. If you were to go with a carbon fiber 16X8 you would probably see a reduction in performance.
The other advantage to carbon fiber is reduced weight but that advantage doesn't hold much water when it comes to props as the wood props are usually lighter. I dunno if a cf prop would be lighter then an APC or not.
Finally comes the "CooL" factor. That one is hard to beat. If you want real CoLl" try a Biela CF prop from Aircraft International. Now that is cool. I think they may have the size you want as well. Just do a google on Aircraft International & check it out.
Old 01-14-2006 | 04:57 PM
My Feedback: (52)
perfect answer, thanks
Old 01-14-2006 | 05:09 PM
My Feedback: (52)
da, they only had a 16*8 too! guess i can't waste my money... they were only like 35$ though
Old 01-14-2006 | 07:28 PM
Blue_Moon_'s Avatar
hi, dident they have 15x8 or 16x5 or someting?
Old 01-14-2006 | 10:43 PM
YNOT's Avatar
CF is airplane Bling.
If you really luv CF, get a heli Bling Bling
Old 01-15-2006 | 01:06 AM
My Feedback: (52)
i had a robbe conquest with as much cf as you can think of.... thats where i came to love it...
