Widebody 60 - CA Models
Hi there again guys...
Has anyone here ever flown the Widebody 60 from Colombo/Anderson Models?
I'm building mine and I'll have a OS 91 FX on it, and for the servos I'll use JR 8411 on the rudder and Futaba 9202's all arround running on 6volts - this "setup" is for 3D training, will this plane do it well?
Fábio Quintal
Brazil
P.S.: Sorry for "my english", it's not my "1st language"...
Fábio Quintal
Brazil
IL
Don from Planes Plus here, we just recieved a containerload of
CA model planes, also the new 3d 2meter plane called the Fantasy. www.planesplus.com 630-904-9983
Yep, I had time to fly my Widebody. Now I just sold it, but I was not disappointed at all.
My Widebody ended with 3,6kg, and, even with a 91FX on its front, I couldn't torque roll it or do a knife edge loop (The plane will do these very well, but my engine had a lot of problems, maybe because I was using a Bisson Pitts muffler.)
Overall, it flies well, and it's very good for F3A and 3D, it's that I just didn't have enough power for torque roll and so on.
I sold my Widebody because I had an opportunity to buy an Aeroworks Extra 300L 37%, but I would have to sell one of my planes to have enough space... And, after all, I had to dedicate some time to my 33% Extra 330L. Ok, Widebody, nice to meet you.
I wish I had taken some photos, it was one of the best looking planes I owned. Let's say I was not disappointed at all.
Best wishes,
Fábio Quintal
Best wishes,
Fábio Quintal
IL
The Fantasy is the same as the Eclipse but has 3d surfaces. I have it both in kit and arc form now and will recieve arfs for Toledo.
Kit 595
Arc 995
Arf 1495
Don
Planes Plus Inc
630-904-9983
Kit 595
Arc 995
Arf 1495
Don
Planes Plus Inc
630-904-9983
NC
hey Don, what power would you use on the wide body. the gentleman above had problems with the OS 91 do you have any recomendations for power and pipe to make this thing have unlimited vertical?
Yep, the problem was with my engine...
I just sold the plane to have enough space for the 37%
But I will say it again: it flies sooooo well... Now I'm sad I sold it LOL!
Back into the engine problem: you really should use a good 90 (I was using an OS 91 FX with the ORIGINAL MUFFLER - do not use pitts as I did)...
I've seen people with OS 91FX torque rolling with less than half throttle! And their plane's weights were very close to mine's.
Ah, and also... I only flew this plane 10 times, so I didn't try much crazy 3d, because the engine was breakin in.
Good luck! This plane is sooooo smooth!
Best regards,
Fábio Quintal
Best regards,
Fábio Quintal
NC
thanks for the info, I'll be getting the OS 91FX for mine...... wondering if it's worth putting a tuned pipe on , or if there's room to put one inside the fuse> guess I'll have to wait and see
Nooooo! You really won't need a tuned pipe.
I wanted to put a quiet pipe on mine (when I had it, of course LOL), but I don't think there is enought space inside the fuse, and, if you put it outside, you'll kill the perfect look this plane has, oh, and the aerodynamical design too LOL!
For those who asked about my scheme... It was EXACTLY like this one Marcelo Colombo uses....
Best Regards...
Fábio Quintal
PS: Now I miss my widebody
Best Regards...
Fábio Quintal
NC
ya that's a nice scheme..... I bet you miss it. well I guess you just save me from going to a tuned pipe... i was thinking it would help a bit.... what muffler would you recomend then.... not sure if the OS comes with a pipe or not?
You can use the silencer that comes with the engine...
Well... but it's a little bit heavy...
I don't know what kind of muffler everibody is using, but if I were you, I'd stick the original muffler.
(Ahh, Marcelo Colombo also uses the original muffler... It's just that you'll have to do a lot of drilling, cutting... look at the manual's pictures and you'll understand what I'm talking about)
Fabio Quintal
Fabio Quintal
NC
thanks for the info, should get mine on monday.... I don't want to cut too much of the cowl if I can help it.. we'll see! got the Funky 40 from CA as well, that one just looked too fun
