Adjustable servo travel
PA
Does anyone use their computer radio's ATV (adjustable travel volume) feature at values greater than 100% to increase control surface throw. If so, how far can you go? Does it depend on the servo? I'm using hitec 605's and 645's.
My Feedback: (16)
TX
You should have no problem with your Hitec's.
I agree with Texas 3D, use all the travel volume your radio can supply and adjust the linkage for the throw you want. This does two things 1) gives the servo the most mechanical advantage 2) delivers the greatest accuracy
My Feedback: (16)
GA
I think the 9C goes to 140%. I have used this when I wanted to get the max throw but didn't have enough analog length. It is best to use this to get the maximum resolution of the servo and not so much as max throw.
