 Twist engine,prop??? >
Old 02-02-2006 | 11:03 PM
setxws6's Avatar
Default Twist engine,prop???
Will a Thunder Tiger .46 make the H-9 Twist a good 3-D plane? If so what prop?
Old 02-03-2006 | 08:35 AM
Ed_Moorman's Avatar
Default RE: Twist engine,prop???
It should be fine. Try an APC 12.25-3.75 prop. I have flown them with OS .46AX, Evo .46 and Tower .46 so the TT .46 should be a good choice.
The Twist is a flat spinning fool and does great waterfalls.
Old 02-03-2006 | 10:36 AM
Walt and Sage's Avatar
Not sure about the TT46 but should be OK...
I have an OS 46ax with a 12x4 Zinger prop with 394 HARD 3D
flights on my Twist.. It is a very strong plane.. well built..
Not the best at 3d but certainly FUN...
Install the battery over the tank to balance..
HAVE FUN...[8D]
Old 02-03-2006 | 08:33 PM
torqmeister's Avatar
I agree with Ed. I have a OS 50SX on mine, it's an absolute rocket.
Old 02-07-2006 | 10:18 AM
I also have a twist with a OS .46 ax and I am pretty sure I'm using a 12x6 and that plane does everything I ask and more. Unlimited vertical from a hover. Don't know about a TT but should be ok.
Old 02-07-2006 | 01:01 PM
My Feedback: (52)
put your .61 in it
Old 02-07-2006 | 04:26 PM
Dealspeed's Avatar
My Feedback: (17)
Im running a 46AX on my twist with a tower muffler, All I can say is WOW!! it was good before I put the muffler on, now its insane.
Im running the APC 12 1/4 x 3 3/4.
Old 02-08-2006 | 11:35 PM
setxws6's Avatar
How much does your twist weigh???
