 Right prop for 3D >
Right prop for 3D
Right prop for 3D
Old 04-21-2006 | 03:05 PM
My Feedback: (9)
Default Right prop for 3D
Hi guys, Need a little help. What would be a good prop for 3d on a 70 surpass on a somethin extra, and a Saito 180 on a Sukhoi. Thanks
Old 04-21-2006 | 03:39 PM
akschu's Avatar
Default RE: Right prop for 3D
I have a magnum 70 (pretty much same engine) and I have been using an APC 14x4W. It has plenty of pull and works better than the APC 13x6N, but I just picked up a MAS 13x5 K series to try it.
Old 04-21-2006 | 04:43 PM
j.duncker's Avatar
APC 14x4 wide for the 70 and try an APC 18x6 wide on the 180. It might pull a 20x6 wide and this will give you easier torque rolls. [ MAKE SURE YOU GET THE WIDE VERSIONS. ]
I like to underprop slightly as the throtTle response will be better.
Old 04-21-2006 | 05:50 PM
daveopam's Avatar
My Feedback: (9)
On the 1.80 I have been tinkering with mine. The APC 18x6W on 15% nitro is a little week. It does not give me the spool up I want. I have a wood Zinger 17x8 on it now and it's pretty good. I have a Zinger pro 18x6 to try and a APC17x6 to try. The 18x6W is just to heavy. 30% would bring it to life and I may end up there. I am just not ready to do that. I was hoping to find a good 3D prop on 15% fuel.
David
