 Large props for 1.60 FX >
Old 05-03-2006 | 09:10 PM
baronbrian's Avatar
My Feedback: (13)
Default Large props for 1.60 FX
Hi all,
I am putting together a new ultra rc giles. I am using a O.S. 160 FX. I have used this motor before with other planes, and always used the APC 18x6w. I want to slow the motor down a bit this time, and want suggestions for other props to try in the 18-20" range. I fly both sequence and 3D. the plane should be about 10.5 to 11 lbs. I want to hear your opinion, If you have tried differnt props and prefer the APC, let me know that to!
Old 05-03-2006 | 09:41 PM
Imac Kiwi's Avatar
Default RE: Large props for 1.60 FX
I have used APC 18x8 and Mejzlik 18x8 with good results on an 11lb model
Old 05-03-2006 | 11:24 PM
My Feedback: (30)
hello Apc 18x6w works very well 13.5 ultimate and extra lots of pull hope this helps.
nitromarc3
Old 05-09-2006 | 11:49 AM
baronbrian's Avatar
My Feedback: (13)
I was thinking a wood prop for better throttle response. any thoughts?
Old 05-09-2006 | 02:10 PM
baronbrian's Avatar
My Feedback: (13)
Has anyone used any of the Prozinger props? any size? what do you think of the performance?
Old 05-09-2006 | 02:45 PM
Bob Pastorello's Avatar
My Feedback: (198)
Pro Zingers.... in ANY size are probably just a notch or two BELOW (okay, WAY below) the WORST Master Airscrew you can imagine. They are SOFT wood, and un-twist on acceleration. They provide TONS of rpms, making the unsuspecting buyer think that he's got a great thing going. Then, the takeoff, followed by sluggish vertical, and nearly-non-existent acceleration from slow speed.
I've used Menz, Mezjliks, Bollys and APC's on the OS 1.60 on many airplanes, up to a 1/4 scale GP Wagstaff Extra. It did a terrific job with a Bambula 18 x 10....
Pro Zingers is more accurately a description of what just happened to the buyer..... he was "zinged" by a "pro"..... save your money....buy a more rigid prop.
Old 05-09-2006 | 06:38 PM
baronbrian's Avatar
My Feedback: (13)
Hi Bob,
In a PM a few months back you mentioned the 18x10; I was a little wary of it because i thought It may be a little fast. What RPM's am I looking for, mid 8K?
I do fly sequences and the prop would be O.K. for that, but how about for 3-D? hovering?
At the moment you have me leaning to the Bambula...
Old 05-09-2006 | 06:39 PM
baronbrian's Avatar
My Feedback: (13)
Oh, also, I AM using a pump, but am NOT using a pipe, I have a BCM pitts- still go for the 18x10?
Thanks bob
Old 05-09-2006 | 06:41 PM
My Feedback: (198)
Can't tell ya about 3D, Brian.... never done it....the 10 pitch COULD be a little fast, but you can always move the left stick DOWN to address that. An 8 pitch probably would give you what you're after, and you'd be approaching 9K.... mid 8's on the 10.... on 15% with a Bisson Pitts, pinched ends cutoff.
Just don't get an un-twister prop... it would really disappoint you.
Old 05-09-2006 | 06:45 PM
baronbrian's Avatar
My Feedback: (13)
O.K., one more question: Have you tried the 18x8 and where is a good place to buy Bambula?
Old 05-09-2006 | 08:34 PM
My Feedback: (198)
RC Showcase sells the Bambula... I'm not aware of other distributors.
Menz standard are DANG good... as are the BME laminated props, and the NX.... All are heavy loaders...
