 Flat trun mixing >
Flat trun mixing
Flat trun mixing
Old 05-22-2006 | 08:28 PM
Josey Wales's Avatar
My Feedback: (61)
Default Flat trun mixing
Before I go out and try this..how do you know how much rudder to use when doing this test? Im guessing that you should use just enough to make the plane turn? If thats the case, then then when you go to do a knife edge pass,you need to make sure the speed and rudder deflection are the same as when you did the flat turns? Ive tried a few times but it seems it takes a whole lot more to get the flat turn perfect then is actually needed for knife edge flight
