 what pump >
what pump
what pump
Old 07-18-2006 | 09:36 AM
Default what pump
What kind of pump for my ST G90 should i use. i will be flying 3D so it will need fuel flow at every attitude.
thanks, james
Old 07-18-2006 | 09:41 AM
bubbagates's Avatar
My Feedback: (32)
Default RE: what pump
If the tank is in the stock location which on most planes is right behind the firewall, you should not need a pump. We will need a bit more information to help you better. Plane, proposed tank location, is the engine inverted sideways or upright, etc...
Old 07-18-2006 | 12:25 PM
the plane is a GP extra 300. the tank is located right on the CG of the wing and above the carb, so there is a long way for the fuel to travel. and the engine is mounted sideways. I am thinking about using the perry pump reg.
