NEW Hanger9 27% Cap 232G!!!! Build Thread!!!
#251
IL
RE: NEW Hanger9 27% Cap 232G!!!! Build Thread!!!
Thanks ggroya1.
Got the control surfaces hinged today and now I need to get some servo arms before I put the servos in.
This is the servos I'm using:
5645 for the Ailerons
5625 for the Elevator
5985 for the Rudder pull/pull
Now what is a good length for the ail/elv servo arms 1" or 1.25" and how long on the rudder servo arm for pull/pull? I think I got a 3" somewhere that should work for the rudder
Thanks for your help
#252
IL
ggroyal great pics and you live in the same town as the company I work for Deutz Corp (Diesel Engines) out on Steve Reynolds Blvd. Sorry to get off topic.
#253
GA
I live on the only section of Steve Reynolds that has houses(the other end from the company you work for) When I moved here 20 years ago it was a dead end road, no trafffic, then the bulldoziers came thru the woods and now I live on a very busy road. I am using all JR stuff, (8411 and 8611a servos), JR790 rec and 7202 xmt, and a JR matchbox for the elevators, also I am using the evolution 45gx2 engine. This was my first gas plane and now I am hooked. I am working on a PAU/BME Edge540 with a DA50 engine for my second gas. I made a diamond template and cut out the diamonds from the Ultracote matching colors. It looks like the Wonder bread bag.
#254
My Feedback: (17)
Can some one post their mixes for dealing with some of the cross coupling on this plane, example rudder to aileron? It would save me some time getting the plane setup which I'm not too experienced at. I only have a couple of flights so far, which has been limited by engine problems and winds.
#255
IL
Ok I'm going to be ordering an inverted wraparound muffler without smoke.
My choices are:
Bisson
Slimline
J&A Engineering
Any have a preference on any of these.
My choices are:
Bisson
Slimline
J&A Engineering
#257
GA
I have the Slimline, don't use the gasket, I use the red rtv hi-temp sealer from Permatex. Make sure you install the bracket that comes with the muffler.
George G. Royal
George G. Royal
#258
IL
Thanks for the info on muffler. I got a new J&A Engineering muffler from a club member who purchased it for a GP Aeromaster and it wouldn't fit the plane. But it fits easily on this CAP 232 and the quality is outstanding.
Now I need to get a spinner, I was trying to find one locally but the Hobby shops have nothing, so on-line I go.
Going to go with a 3.25" lite-back from Tru-Turn.
(Edit) Forgot to ask is Chief Aircraft a good place to order from or should I just order direct? Thanks, in advance.
#259
GA
Call Stephnie at Truturn(281-479-9600), they are real nice people. Tell Stephnie you talked to me.
George G. Royal
George G. Royal
#260
My Feedback: (21)
Using a DX7 my cap required a 15% mix rudder/elevator with both right and left rudder to offset most of the coupling to the belly when in knife edge. High alpha knife edge or knife edge loops need even more than that but i just fly thru those and feed in whatever is needed because if you try to mix all the coupling out it will mess you up for doing rolling circles and rudder turns. I found so little roll coupling that I saw no need to set up a rudder/ailerone mix. I did set up a throttle/rudder mix for the uplines as the the plane pulled to the left at full throttle. The mix is set at 10% and feeds in right rudder as I increase throttle past 1/2 stick. That is using a DA50/Vess 23A If you stick to 22" props you might use less mix.
take care
zonk
take care
zonk
#261
GA
This may be a dumb question.. BUT.. Here goes.. I fly all Glow.. I am going to make this my first gas.. There is a guy at the field trying to get his Evo 45 to crank and can't.. I am the king of glow at our field and they ask me and I just shrug my sholders.. Is there any pointers on the gas and where do I start reading. I tried the Evo manual. LOL.. Tells nothing that I need to know to help this guy...
LATER
LATER
#262
GA
Well I decided to go with the Saito 220... WOW... This thing has some power. It will hover at 1/2 throttle with plenty of climb out.. I have some more tinkering to do with it and It will be the show stopper... Flys great like it's on rails and snaps--- like a CAP!!
LATER and thanks for all the pointers..
PS.. AUW was just 15 lbs.. well 15.1
C-Ya'll
C-Ya'll
#264
GA
Hey Mr Powerlines,
I have been flying the H9 Cap232g for nine months. The only problem is the landing gear. I have a CF from Graftech to replace the stock one that sometimes bends a little on windy days. This was my first gas plane and it got me hooked on gas. I now have two more 30% planes. A BME/PAU Edge540 and a Aeroworks Extra260. The cap has the Evolution 45gx2 that has been flawless(not using the auto choke). I am using the aux2 for the choke. The 45gx2 does not like regular unleaded gas. I found out when I put the reg. in by mistake. I did reinforce the firewall and the the landing gear block. Eveything has been holding up great. I really like the ultracote covering, it stays on better than monokote. I also change the tail wheel to a Troy build model for $25.00, simple but it works great. You can't beat the price and the hardware is very good(pull-pull on the rudder with JR8611a servo), Jr8411's on the ailerons and elevators + JR matchbox, 7.4v lipos and 6v regulator for the receiver.
I used a Red Gem 2000 voltage monitor for the rec. bat and a blue for the ign. You can see them flashing from a long way off.
George G. Royal
George G. Royal
#265
My Feedback: (10)
TN
Hey all, if anyone's still on this thread I'd appreciate some input. I just tanked my Alitalia Cap last wk'end <sniff> due to a servo mal-freaking-function, and have been toying with getting one of these diamond cover'd H9 27%'er, as opposed to finding another Alitalia. I kind of like the idea of plug in wings instead of toting around a 1 piece 80" monstrosity. What's the word on this 27% version? Likes? Dislikes? Bad habits/a piece of cake? Any opinion appreciated. Oh, 1 more thing. would a Moki 2.10 be possible on this? Flew the Alitalia version like a dream, plus I'm not real wild about plunking down for the much loved DA 50 when I have a perfectly good Moki.
#266
ME
ORIGINAL: Sense963
#268
ME
ORIGINAL: Sense963
good stuff, sir. what did you use to mount the Moki? radial backplate or what?
#270
GA
They did.. It would not draw fuel from the start.. It is fine now.. We had a guy at the field that put it togeather.. I have to say'' it was the worse flying plane I have ever seen.. Tons of mistakes that I saw on the ground.. I was NOT flying it.. One of our other less caring pilots flew it.. I went out to give him a hand and after making one pass with it I told him it was not getting on the ground in one piece.. He did it.. I do not know how.. That is the one with the EVO 45..
Mine with the Saito 220 has plenty of power. Hover at 1/2 and enough pull out.. No a rocket but the wing load is unbelievable.. STABLE!! I love it.. just a touch over 15 with no fuel.. It is be far my favorite plane to date.. Motor will fire with one back bump... It is very hard to tip stall and Knife edges like crazy.... LOVE IT!!
LATER GUYS And thanks for all the info!!
#271
My Feedback: (34)
Perhaps you had the CG too far aft - I did at first and it was not the best flying bird -moved the cg forward and it smoothed out to be a fine plane ....email (or PM) me and I will tell you where there is a review and flying video of the plane (w/Evolution 45GT)....
#273
GA
The bad flying plane was not mine. I thought It was a bit tail heavy but not bad. I do not know what the problem was.. I was keeping out of the mess,, If you know what I mean..
My 232 Flys like a dream.. I love it.. I think I need a 18x6 or a 20x6 to hover and pull out good and also SLOW the landing down..
LATER
LATER
#274
GA
Hey Powerlines,
Have you tried the optional Saito pump that is shown in the Horizon Hobby website?
George G. Royal
George G. Royal
