3D props for MDS 148
My Feedback: (7)
I use a 16x8 apc on my sig cap but that is only because apc does not make a 17x6 which i think would be awesome.The only 17 " props i can find are wood and i refuse to run wood props. This engine actually turns an apc 18x6 real well, around 8200 rpm's, so thats not bad at all, but i like the way the 16x8 flies this cap a little better .
My Feedback: (7)
WOOOHOOO !!!!!!!!!!!!!!!! apc does make a 17x6 !!!!!!!!!! im goin to order one right now !! , in my humble opinion a 17x6 would be a better 3d prop than either the 16x8 or 16x6 , but if i had to choose between either it would be a 16x6 for 3d and 16x8 for sport, some manuevers really are hard to do with an 8 pitch prop on certain setups, try both, you never know what your set up may like the best . Mike.
