 Hover help >
Hover help
Hover help
Old 10-03-2006 | 08:38 AM
pizza's Avatar
My Feedback: (24)
Default RE: Hover help
most foamy, .46, .60, .90 size 3d planes on the market have a small flat stab, rudder and tailpost to save weight, uild time and cost. this is a disaster when it comes to hovering. hover planes need an oversize thick built up stab/rudder/tailpost makes them less pitch sensitive. air from prop passing over a thick tail group will lock it in - keep the tail steady in hover like an invisable hand holding the tail in verticle. a hover pilots worst enemy is a sensitive tail that is all over the place. are there any light balsa 3d airplanes with a big oversize builtup tail group out there?
Old 10-03-2006 | 01:03 PM
Ernie Misner's Avatar
Build the Mojo in a couple of days maybe? I thought it was a kit rather than an ARF. Anyone have a link to the Mojo??
Ernie
Old 10-03-2006 | 01:51 PM
My Feedback: (13)
ERNIE
www.billyhellrc.com
www.swanyshouse.com
Old 10-03-2006 | 03:35 PM
I ordered a Mojo, should be here anyday. Im going to use a ST 51 on it. Should have plenty of pull with a 12.25-3.75 on it.
Old 10-04-2006 | 02:39 PM
MIXMASTER's Avatar
My Feedback: (15)
EF Yak and I believe the Showtime 4D have airfoiled tail group. I remember hearing that from the best flyer at our field,he said the best way to go was a 3-D plane with airfoiled tail group,which I promptly followed his advice with the EF Yak,pretty light for 68" wing(9lbs) with Saito 1.50,I couldn't hover that *itch for a few seconds even after pushing the engine out like they said. I added tons of up-thrust to no avail. But then again it took me 3 years of tryi ng to get into the groove with a Do,first I had to learn what the plane needed to hover easier/better-usually up-thrust,more right thrust,I had to figure out what was the best prop/engine combo,fine tune the prop to allow more "slippage" downward,better throttle response,then I still needed to fly more to get my first tail touch and I need to do it when its light wind or it drifts too much. All this without a sim or foamy to help. This is the hardest thing to do in 3-D IMO,especially when TR'ing,actually it may be the hardest thing to do period, with a model plane. If you can afford it,get a good sim,a foamy,pal around with a good 3-D flyer and buy a known good 3-D plane,then you still have to burn a lot of fuel.
