help
Old 09-30-2006 | 03:23 PM
Jonathan.Lam's Avatar
Default help
i have an adrenaline 120, all of the maneuvers are perfect except the harriers, they cant stop wing rockin, does anyone have any ideas on how to stop this?
thanks
can i also ask does anyone have the adrenaline powered by a saito 125, how much throttle do you need to prop hang?
thanks
Old 09-30-2006 | 06:41 PM
gjeffers's Avatar
Default RE: help
Chinky, my saito 125 hovers my ucd that weighs 7lbs 12oz easily at somewhere around 3/4 throttle, i use a apc 16x5 prop and get about 8800 rpm. im not wure how much your plane weighs but maybe this will give you some idea how the 125 performs, i like mine.
as far as the wing rock, ill let someone else chime in, ive never been able to cure mine on my ucd60.
Old 09-30-2006 | 07:28 PM
rcflyer1970's Avatar
My Feedback: (212)
Default RE: help
I use both ailerons up on my rotary knob, like flaperons but in the up position helps on some planes, if your radio has that feature, or you can usually program a switch and experiment with how much deflection works best. You can see it on this video and some others 3D Flying Texas Style at http://www.blaineaustin.com/videos.htm
Old 10-01-2006 | 04:06 AM
Default RE: help
thanks, i just got told going inverted for harriers are easier. so im going to try it out at the field, thanks for the reply anyway.
