 Hitec Eclipse 7--left Aileron setup question???Helpp!! >
Old 10-20-2006 | 10:18 PM
Default Hitec Eclipse 7--left Aileron setup question???Helpp!!
Hi,
I have a Ultra Mini Stick with Hitec Eclipse 7. I am new to airplane, I use to fly Heli. I have all the servo working properly but just couldn't figure how to make the Left Alieron to move. THe manuel said CH6 is the left Alieron, which is where I plugged the servo into, but it not moving at all. I checked with another reciever and servo, both behave the same, so it must be a setting.
Can someone tell me how to setup the left aileron properly?
Old 10-20-2006 | 10:52 PM
Planeclothes's Avatar
Default RE: Hitec Eclipse 7--left Aileron setup question???Helpp!!
Make sure the flaperon (FLPN) function is on, you can only use dual aileron servos when this function is on. This allow for you to set your centering, EPA, etc. individually for each servo.
Old 10-20-2006 | 10:54 PM
Flaperon is on, tried that. No luck. I am using 4 hitec hs56 and electron reciever.
Old 10-20-2006 | 11:00 PM
Cyberwolf's Avatar
Yes its a setting thats inabled.Go to page 13and 14 in your book ,I think it has it all right there .
Old 10-20-2006 | 11:10 PM
OK, if flaperon is on and channel 6 EPA is not set to 0 the left servo should move. Try switching servos and double check connections. I assume your tx is not set to heli.
Old 10-21-2006 | 06:24 PM
It's in Arco, Flaperon is on, EPA is 100%. Tried 3 servo and 2 different reciever and connection is good. Left Aileron(CH6) is not responding.
What else I can tried?
Old 10-21-2006 | 09:14 PM
Try a different model # or reset your memory and start again, following manual directions beginning on page 13. If it still doesn't work, you probably have a defective tx.
