 Need A New Plane Help!!!! >
Old 11-16-2006 | 09:44 PM
mikeygp's Avatar
Default Need A New Plane Help!!!!
Ok guys need a winter project to build. I am looking for a 40 size laser cut kit to build I want it to be a full fus not a profile. It needs to be fully 3D capable I am having a hard time finding what I am looking for. I would think that there is a kit out there.
Old 11-16-2006 | 11:18 PM
stinger40's Avatar
Default RE: Need A New Plane Help!!!!
SIG Somethin' Extra.
-3D Capable.
-Laser Cut Kit.
-40 Size
Any more Questions?
Old 11-16-2006 | 11:28 PM
mikeygp's Avatar
Thanks for the input but I am looking for somthing a little more scale then that. But thank you for the input keep it coming. An example would be like the powerline edge but a kit not an ARF. http://www.powerlinehobbies.com/
Old 11-17-2006 | 07:34 AM
Electriceddie's Avatar
Mike,
Thats kinda small and not what I would really call a .40 size plane, you can find something better. Be patient check around. I will see what I find as well. Off the top of my head. What about the "U Can Do 3D" 40 size, the Tower hobbiess "Uproar" (Good Plane), The Funtana or Great Planes .40 size Extra 300S all of these planes are between $50.00 an $170.00. All can be found on the Tower Hobbies web site. The Uproar and the Extra are kits, the Funtana and the U Can Do 3D are ARF's
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJA52&P=ML[/link]
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJ579&P=ML[/link]
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDUL8&P=7[/link]
[link]http://www.horizonhobby.com/Products/Default.aspx?ProdID=HAN1975[/link]
Ed
Old 11-17-2006 | 11:52 AM
mikeygp's Avatar
Thanks for the input the Great Planes Extra 300S 40 Kit is what I am looking for but in a laser cut kit sorry I am being so picky.
Old 11-17-2006 | 05:14 PM
YNOT's Avatar
Look for a Laser 3D.
Old 11-18-2006 | 03:46 PM
Whats the big deal with a laser cut kit over die cut? I build both types and if they are manufactured by the better companies they go together fine. I have had some laser cut kits that were really bad. We can't pick a kit for you because your the only one that knows your tastes. This is a loaded question to ask at best.
Gibbs
Old 11-18-2006 | 06:29 PM
Mike,
I agree with NCIS. If you want to be that fussy it's your time and money, however you will limit your choices severly. I prefer and good Die cut over a lazer cut. You will need to sand off the lazer burn on the edges for a good glue joint.
Ed
